muench don
Posted on - 05/24/2012
Hi! I want to change my Windows Operating System with a Vista SP1 but everytime I install the service pack I always receive an error message that says: An internal error occurred while installing the service pack, Error code: 0×80070490. Can you please help me identify the problem and the best solution for it?Â
Windows Vista SP1 Installation Error
Dear Don,
You have problem in installation of windows vista. It shows error when installing. Error code is 0×80070490.
Here are some tips to solve your problem-
**Enter the DVD of windows vista.
**Restart your computer.
**Press any key to start installation.
**Now follow the procedure.
**Click in custom installation.
**Now select the partition C
**Delete partition
**Create new.
**Format the Partition C
**Now click on partition C and start installation.
**Complete the installation procedure.
**Now install you necessary software in your computer.
**Now you are ready to use your computer with windows vista operating system.
I hope you get your answer.
Have a nice day. Thank you.
