joey keen
190 points
Posted on - 02/02/2013
Windows Vista vulnerability is having the problem of that a direct connection is via a Patch Cable between two PCs or PC and Xbox, will detect as "Unidentified Network Binding", with applicable restrictions, (for example, the place are not of "public "at home" home “) with a router in between doesn’t exist this kind of problem.
Now I don’t have a router in the area and it’s also not needed for now. Few days back I found a work around for this problem exactly on the web, but no relief found for my issue.
So I turn to you.
Regards,Â
Hi there!
Is it the first time you have encountered this error? Have you already tried rebooting your devices? Usually rebooting or doing a power cycle on your devices will fix any issues that you might have. Try to check your IP addresses as well (ipconfig /all).
Have a wonderful day!
Hello Joey,
I am sorry to hear you are having difficulties with the direct connection.
First, if you haven't done this before, make sure you have run the Network Setup wizard.
Launch control panel, look for network and internet sharing and select "Set Up a Connection or Network link"
Follow the onscreen instructions and hit the Next button.
Note: This process needs to be run on the other computer too. To make it easier, get a USB flash drive and save the configuration and run it later on the other computer.
