In Windows, what is Safe Mode used for and why?
In Windows, what is Safe Mode used for and why? what exactly it does, how it helps? Can somebody answer?
Safe mode is very important for fixing some problems in our computer. By going in safe mode, your computer has might have problems, usually due to a virus or because the computer application is not true or you corpulent fix your computer is damaged. It could also repair even those damaged drivers that makes your computer unable to boot properly.
Boot in Safe mode is very important in computer development, usually it appears "Do it in safe mode" (see attachment), it is suggested when the computer got a virus-resistant viruses are hard to remove. In safe mode the OS will run in a minimalist and all applications will be put to sleep, so it is very effective in removing viruses because the virus will lose its immunity.
Steps  on How to Boot in safe mode.
Computer safe mode is used when computer gets mess-up. This allows you to change the settings, reformat and work on computer's specification. Do the work around to fix damaged files, add, edit and delete files. Remove virus infections and clear boot menu file.
You can disabled programs, hide the context and other files that is not accessible during the normal start-up.
This is being access if you need to do the major changes of your computer, specially if you want some software and other components disabled.
