I have a Windows XP computer with a hard disk memory of 40GB. It is too slow for and the memory is also too small for the files I want to keep in it. It is also unable to run quite a number of applications. It also freezes a lot while playing MP4 video files. Is there a way in which I can make the computer work faster and also increase the memory to a bigger capacity?
Windows X PC Too Slow. What to Do?
Now the computer is having a memory of 40 GB. Because of the lack of memory space the computer may become slow.
Check the RAM capacity of the computer. If the RAM capacity is less, then the computer may become slow. That’s why while loading the MP4 video file, computer getting slow.
If you are running so many numbers of programs together, because of the less RAM capacity, then computer will become slow.
It is better to buy an internal HDD (Hard disk Drive) and RAM for the computer. You can change the internal HDD (Hard disk Drive) and RAM of the computer. Thus you can increase the memory capacity of your computer.
