Windows XP animated fine cursors required
Hi All,
Animated fine cursors for Windows XP is needed for my system which is already loaded with funny stuff and would be of great help if anyone can help me finding such Cursors for my system.
Animated cursors for ideal state as well as reading is needed.
Please give me complete explanation on how to activate each as well
Thanks
Answered By 40 points N/A #91205
Animated cursor does ignite the desktop experience with variety of cursor available on the internet for free and paid, I have arranged a couple of link which contain lot of animated cursor design, Music light, Turtle, Plan, Plus you can Edit create manage,and so many things can do with these cursor, Now you can find the link given below,
http://www.cursors-4u.com/
https://en.softonic.com/s/windows-xp-animated-cursors
Thanks
Answered By 590495 points N/A #315935
Back when I was still using Microsoft Windows XP, I love seeing my mouse cursor in different themes weekly. Windows XP itself already has different skins for the mouse cursor but it tends to get boring in the long run. If you like your mouse cursor look different every now and then, go try using CursorXP. It comes with different themes when you install it.
If you want to try it, download one of these two:
CursorXP allows you to take advantage of the new visual effects features of Windows 2000 and Windows XP. If you want more themes to use on CursorXP, download your desired themes from these two websites:
