Federick
Posted on - 08/27/2011
Hi Experts,
Windows XP how can I clear the search history? When I search files in my machine the typed search is saved for future use. But I want to clear that How can I clear it? Not Internet Explorer rather the windows explorer.
Shahid78
How to clear search history on my Windows XP
The search history stored in the registry, to remove the search history follow these steps.
Click start / run / typed regedit
Navigate the following key:
HKEY_CURRENT_USER Software Microsoft Search Assistant ACMru 5603
In the right pane, delete the search items.
Close registry editor.
Close all the open windows explorer:
Begin the registry editor.
Input this on the registration field HKEY_CURRENT_USERSoftwareMicrosoftSearch AssistantACMru
Now choose and remove all subkey below the ACMru
Then turn off the registry editor.
You need to sign in and sign out before you do new searches.
As I validate my solution using different search engines on the internet, there are various ways but most of them require registry editing. I will show you a trick in a more simple way.
Right click the taskbar, the bar beside your start menu button, (it is easier if you close all open windows for you to be able to click the taskbar not the window of an open program) then choose properties, click the start menu tab, then click customize, on the general tab, click clear list button, beside the general tab is the advanced tab, click it, then click the clear list button. Close everything and you’re done.
feroz666
Dear federick,
In Windows XP how can you clear the search history? Well its simple. Do as I say, go to the website https://filehippo.com/ and download the latest version of "Ccleaner". It's a cleaner software for your PC. It clears cookies, history, dns cache, recently types url, index.dat files, prefetch, temp, memory dumps, FTP accounts, save passwords.
Its a very handy software and easy to use. Installs in seconds. After installation click "analyze" after analyzing click "run cleaner". You can do it either by manual registry tweaking or try automated software like "Ccleaner". Will be glad if its help.
kathrynn
I have the same problem. Thanks, Shahid78. I followed your instructions and I was able to clear my search history in Windows XP.
