larryiresto
30 points
Posted on - 06/07/2012
I have a problem when I try to install windows XP. When I chose third party installation and then I click F6, but after that it is just showing an error message that "an unexpected error (1333750144) occured at line 1773 in d:xpsprtnbootsetuparcdisp.c".
I can't continue the installation. Please help me, because I have some work to do in XP.
Windows XP installing error need help
You shouldn't must press F6, here is regarding "Third Party DRIVERS" not for regular installation.
One pick installation include eliminating all record from your challenging disk via reformatting your own challenging disk as well as reinstalling both the platform and then applications so that you can a great empty (fresh) difficult disk.
As well from your CD/DVD, your BIOS gaps inside your pc must be configured to accomplish this. In open hold tapping sometimes F1, F2, F10,(Realize that a number of manufacturers benefit from F10 with regard to machine improvement!) Esc, and Del, so that you can go into both the BIOS set-up. Ask for "Motivation configuration", "Boot buy" as well as other and produce your CD/DVD drive your daily initially boot device along with the drive second. Help save gaps and quit.
Add a disk into your CD/DVD energy, and then reactivate your pc.
If you meet the "Drive virtually any key to boot by CD" message, thrust a significant to begin both the computer in the CD/DVD.
Obey a words along monitor to help choose and even release (NTFS) an partition where by someone want to fallen Microsoft windows.
Follow your daily assistance on the computer screen for you to full the Windows xp If you are.
Get some Anti-Virus safety, promote and revise Computer.
