VMware is currently established on my computer. I placed the Windows XP installation disc into the disc component of my computer and when I commence the virtual tool provided by vmplayer it’s not uploading the disc. I’ve adjusted the boot sequence although it won’t upload. Do you have any other solutions that could help me fix my problem so that I can install the windows program onto my computer?
Windows XP isn’t uploading onto VMware
You did not mention details about the error in your VMware. But I can give you some suggestion regarding that issue. You are currently unable to upload in VMware. You may follow two different methods to resolve that problem.
Your operating system may create obstacle to use VMware in your computer. So if you want you can change your operating system in your computer. I will recommend you to use windows 7.
Your installed VMware software can affected in versus. So reinstall VMware software in your computer again, that’s better to download again that software from internet.
Hope you are understood.
Thanks
