Are there any Windows XP software that can connect PC to the internet through iPhone 4S?
My iPhone 4S is not connecting to the PC run by Windows XP. So, I cannot use 10GB internet plan with my phone. Â
Apparently it works on the laptop using Vista Operating System. Â So, is there any way that I can use my iPhone on Windows XP.Â
Windows XP Software for Connecting PC to the Internet through iPhone
Hello there user,Â
I think your Vista OS is not seeing your iPhone as a plug and play device; all you need to do is have iTunes installed on your computer then plug-in your iPhone. ITunes is an all in one application that can SYNC your phone and your files, a music and video player too.
To download iTunes just go to:Â iTunes website.
Hope this helps your problem.
Waall Mike
You need to install iTunes on your Windows XP PC to synchronize your iPhone to it. You can download iTunes from the link below:
https://www.apple.com/itunes/download/
Install it on your XP machine and then connect your iPhone with an Apple USB cable. If you already have an iTunes installed on your XP, ensure that you are running the latest version.
