Hi Techyv Friends, I am using Windows XP Vivo Tab ASUS. My friends told me that ASUS VivoTab will work more comfortable with Windows 8 rather than that of Windows XP, So I am planning to install Windows 8. Please give expert advice on this matter. My usage of ASUS VivoTab is very limited with office applications and Internet usage. Thanks
Hi collen,
As I came to know that you are currently using Windows XP vivo tab ASUS.The best suggestion you will get from ASUS technical Consultant discuss your matter with them and if they told you to do so still i want you upgrade your tab ram if possible .hope this will provide you a little assitance
Thanks
Good day. I am certain that your friends are right. ASUS Vivo tab is more compatible in Windows 8. For installing Windows 8, there are utilities for backing up the drivers if they are not available in public which needs to be done in a working system before anything goes wrong.
