Winfast TV2000 Girder plugin error
Recently I installed Girder for use with my TV2000XP, install was fine, program and TV2000 specific plug-in both was installed successfully. When I tried to load the plug-in this error message box appeared and now is not working at all. Can anyone help me to fix this ? What I did wrong ?
Thanks !
This function requires a video capture device based on the Brooktree (Conexant) BTB848(A), BT849, or BT878 chip. None could be found. Are you sure you have one?
OK
