WING F T P Software
Hi
I downloaded a testing version of wing FTP. However,I got the script error.
I have installed it on windows server. IE 8 (script enabled)
I need a solution. Please help.
Internet Explorer Script Error
Hi
Hello Chad,
The error you are getting occurs when there are hypertext template (.htt) files on your computer that are damaged. To resolve the issue, you will need to use the workaround below:
You will need to get rid of web customizations. In the event that several folders are resulting to the script error, you will need to get rid of the web customizations from whichever folder that brings up the error message. To be able to remove the customization from a folder, you will need to follow the steps listed below:
Carl
