I tried to run WinLIRC first time but it failed to initialize.
I want to use it properly so what should I do now?
Is there need to configure it?
Please provide the solution step by step so that I may follow the instruction easily.
Thanks in advance.
WinLIRC Error
WinLIRC failed to initialize.
Would you like to change the configuration and try again?
WinLIRC failed to initialize on the first run
Hi James,
The error is due to incorrect installation process.
To resolve this error, follow the below steps:
1) Click 'OK' and change the configuration
2) In the WinLIRC configuration window, verify the port listed is same to that of serial port of the receiver unit
3) Click 'Browse' button to select the configuration file saved in the system
4) Click 'Analyze' button
5) When the analysis of configuration file is completed, message 'Analysis successful' is displayed
6) Click 'OK'
