Winrar .jr* file extraction error
Hello, I have a simple question for you users.
When I tried to play a game named fishsim2. I have to use WinRAR to extract the jr3 files to the games folder.
But every time I am getting an error message and cannot get rid of it anyhow.
Here is the error message: ! C:users-noddy-desktop26weatherfiles.zip: cannot create 26weather files 30_10_2007.jr2 ! Access is denied.
Can you tell me why this is happening and what could be the solution?
Thank in advance and really appreciate your help.
Answered By 20 points N/A #91912
Hey Mandy miller!
There is a possibility that the message occurred due to WinRAR. You have to run the WinRAR as administration.
Or if you are not using the Administrator account then you must have to login from the Administrator account. If you are using windows Vista or Windows 7 then you have to right click on WinRAR and run it as Administration.
If the problem does not solve, then you must try some other tool for uncompressed the data.
You can download 7 Zip.
I am going to add a link here for you.
I hope that it will help you.
Thanks
