WinZip Self-Extractor License Confirmation message
Hello Guys here. I have a problem which is not to be my problem; the problem is my licensed Winzip throws an error which is telling me that it’s not licensed.
What can I do with my Winzip to make this licensed again and work good?
Your version of WinZip Self-Extractor is not licensed, or the license information is missing or corrupted.
Please contact the program vendor or the web site (www.WinZip.com) for additional information.
OK
Best Answer by darksoul0000001
Answered By 5 points N/A #118851
Dear,
Please firstly disable your Antivirus.
Then remove Winzip (OLD) from your control panel which was installed in to your computer.
Then Go to download.cnet.com/WinZip/3000-2250_4-10003164.html.And download Winzip from this site and reinstall in to your computer.
In this way you can get a solution.
Thanks
Answered By 0 points N/A #118853
Step 1: Go control Panel > User Accounts > Change User Account Control setting  then  drag the bar in bottom
Step 2: Go Local Disk(C:) > Program Data > WinZip than delete your registration info and restart pc and try to register again.
Another solution: I suggest you to use 7-zip which give you better performance than WinZip and it is a free software so no license issues. You can find it from here
