Wireless charging for iPhone 4s
How can I charge my iPhone 4S using wireless mode? Is there any possibility for this to work ? How much time it will take to completely charge the mobile using wireless?
There are few electronic devices which support wireless charging. IPhone doesn't support internally any wireless charging but you can still achieve it buy using different 3rd party devices. For this to work you need to buy a device named Powermat Wireless Charging which will allow a user to put the mobile in that device and charges your mobile directly. This devices will in feature comes in the computer itself but at present it has not yet launched for computers. You can buy this from the below link
https://www.amazon.co.uk/Powermat-Wireless-Charging-iPhone4-4s/dp/B00462QB3I
This thing doesn't cost much when you expect you want to have a wireless charging.
If you want to experience how to charge you iPhone 4s wirelessly, try Duracell Powermat for iPhone 4/4S. This is on eBay which costs $4.45. With this, you can easily charge your device as simple as placing your phone on the Powermat charger.
The protective case allows the drop-and-charge power which works by not only charging your phone but also protects it against bumps and drops because of its durable shock-resistant built. Another one is the Powermat One-Position Charging Mat on Amazon. It costs $9.99. Wireless charging has been a feature of a number of Android Smartphones but this technology has never appeared or featured on Apple’s iPhone, its flagship Smartphone.
Notifications
