I have read in different places that Comcast is the best application that you can use to mirror a tablet to a TV. However, I need to mirror a laptop or desktop to TV. Can Comcast do that. If yes, how do I make the settings? If there are other options, inform me please. It is not necessary that it should be wireless.
Wireless mirroring of a tablet to PC
There is a way to use your TV set as a second display for your laptop via an HDMI connection. First, check if your TV can connect to your laptop using HDMI or if your TV has an HDMI cable. If it supports HDMI, connect the HDMI cable of your TV to your laptop’s HDMI port.
Since the LCD on your laptop is functional, your TV won’t immediately display the images from your laptop. To display the images on your laptop to your TV set, you need to enable dual display on your computer. To do this, right-click any blank area on your desktop then select Properties. In Display Properties window, select Settings tab.
Select 2 from the display options then click OK. Restart your computer then check if your TV is now showing what is displayed on your laptop.
