I have a Fujitsu Siemens AMILO and it used to pick wireless network with no problem on Windows Vista, all I had to do is to press Fn and F1 simultaneously and the message in the attached picture would appear. So I switched WLAN on and it would work, ever since I installed Windows 7 the wireless stopped working. It doesn't display any error message, I am still able to connect using the USB modem but pressing the short buttons for wireless are no longer activating it .
Any idea how to fix this issue?
roran08
10 points
Wireless Network Issue on Fujitsu Siemens
Hi MissDollarBill!
One of the possible reasons why your wireless laptop stopped working is because the driver of the built in wireless adapter on your laptop is not properly installed or is not compatible with your new operating system. Please check this link for driver download.
 If in any case, the link above does not give you the driver or there is no driver for Windows 7 and you would not want to go back to Windows Vista you have the option to buy a different wireless adapter. You can go with a wireless card or a wireless USB adapter and that is available in any computer store.
