I have an Apple AirPort Extreme and I want to setup my home wireless network using it. The problem is, I don't own a Mac and all our computers at home are Windows. Can I connect to the network even if I use a Windows PC? How exactly do I set it up? Do I need to install any software? Any help would greatly be appreciated.
Wireless network using Airport Extreme for Windows PCs
This device does not require an Apple PC. The setup is virtually identical to the setup of any similar technology. Ensure that your Windows PC is updated and that you have any drivers required by the device. Utilize the same guided software bundled into your Windows OS to setup your router as you would with any other router. The only problems that may occur are from software in need of upgrades.
