Whenever I try to open word processor in Works 8 I keep getting an error message about a .dll error message.
I am receiving the same error message when I open any of the other programs within Works. I have the software installed on my Windows XP machine.
I have already tried the uninstall/reinstall process, but it does not make any difference. Any suggestions would be welcome.
WksWP.exe – Entry Point Not Found
The procedure entry point ?CwchSzToWz@MWblStrings@@SAHPBDPAG@Z could not be located in the dynamic link library
WkWbL.dll.
Exe file errors is cause by a corrupted windows registry, it is due of an invalid entries because of a software that you are no longer using it, or another cause for it is an improper software installation or removal. When you fail to fix these corrupted registry it can result with a harsh PC problems.
The basic step you need is to identify whether or not your windows registry is broken. Consequence in a damaged registry is an ability of your windows to locate the specific path and executable and end up an errors.
All you need to do download a registry fixer software and restore the point that can be restored. Here’s the link
http://www.topregistrysolutions.com/exe/?cd=EXl1860
