I am using Windows XP Home edition. I need to burn RM to Audio CD. The ‘StreamBox’ ripper is to be required for converting RM to MP3 and only after the conversion that it can burn. So, I have downloaded ‘StreamBox’ ripper Version 2.009 and it is coming with ‘StreamBox VCR Suit Version 2’. I have downloaded the same for yahoo. But the ‘StreamBox’ ripper is giving me an error. ‘The software is failed to open due to the file wmaudsdk.dll is missing. Please re-install the software to correct it.’ So, I have re-installed the same, but there was no change in the result. If any software is there to burn RM to Audio CD, please inform me. Please help me to fix the problem. Thanks in advance.
Wmaudsdk.dll is missing in StreamBox ripper
Hi Tricia,
You may want to check if the wmaudsdk.dll has been transferred to the Recycle Bin. Sometimes we accidentally delete some files. Just try to restore it if it is there.
If it is not there, try to run a virus or malware scan on your computer.
You can also try to do a system restore as a recent change on your computer may have resulted to the file being removed or deleted. To do system restore, just click on Start > All Programs > Accessories > System Restore > Choose a date before issue started.
You can also try to reinstall Streambox and see if it will automatically reinstall the dll file.
Aristono
Hello!
If you want to burn RM to Audio CD, you don`t necesarily have to use the StreamBox software. There are many other possibilities to do this.
For example, you can download another software that will help you directly burn the CD, without pre-converting the file. You can take it from here: Download Burn Software
The CNET Site is one you can trust. You can use it just this once, so you should download the Trial Version, otherwise, I strongly recommend to buy the software, if you are pleased by it`s features.
