Jo Opheim
65 points
Posted on - 08/29/2012
Hi! I'm a computer science student and just about to learn about javascript. As I browse the internet about it, I found that there's what you call "jQuery" that will help people to learn and use javascript the easiest way. It says that it will help me to understand and to work on with HTML but the details in each sites are already "programming explained". I just wondering if there are sites or information that you can give to me as a general facts about this and also to this dynamic jQuery list search that some sites are talking about. It is really a great help! Thank you in advance!
Wondering about dynamic jQuery list search
So what you need is explanation on what JQuery is and the useful of it? well I will recommend you to see this site. https://en.wikipedia.org/wiki/JQuery
I recommended you that because there are some links and references there that will be useful for you. If you want to learn programming JQuery I recommend you https://www.w3schools.com/ which is the site where I learned a lot about programming. You can learn general facts about programming language from w3schools but they are more on programming explained tutorials which you mentioned above that you don’t need, anyway its just recommendation.
Good luck. Hope this helped.
