Wondering if there is a file cleaner for linux suse?
I just moved to another operating system called Linux and was wondering if there is a file cleaner for Linux suse? I am transferring so many files from my external disk to my computer. Your help will be much appreciated.
Answered By 10 points N/A #129668
There are a few cleaners available for Linux SuSE. Before you download them, check the version of your system and verify whether the software is compatible with it. This is an important step as the software will not work if it is not compatible with your system. Most of the software is free to download and use, some of them come with a 30 day trial period. The following are some of the trusted cleaners for Linux suse.
1. gconf cleaner – You can get it here – https://code.google.com/archive/p/gconf-cleaner/downloads.
2. BleachBit – You can get it here – https://www.bleachbit.org/. It is a very efficient software and has many options. See the screenshot below:
Bleachbit cleaning software
Hope this information helps you.
