chachajutex
10 points
Posted on - 08/17/2011
I am using Microsoft XP and Office 2000. Now I faced a major problem. After PC on the word file automatically open. Every time when after show desktop the word come in.
Is it any virus or other critical issue?
Is it possible to solve it easily?
roseman
Word automatically opens after opening windows
Hi, it is a great problem. Mainly I think it is a virus problem. You should scan your computer by update avast antivirus. Other way you can uninstall your office XP software. Then you should new install your office XP with restart your pc.
I think help you very much.
Hi Chachajutex,
It is neither a major problem nor a virus. It seems that you have put your word file in Windows Startup. You can easily remove this. Type “msconfig” in RUN, and a dialog box will open. Click on startup, and remove the tick from the file which you do not want to run during Windows Startup. Thanks.
Dear,
When a virus attacks on computer, it slows down the performance of computer and starts to damage the files and data.
In Your computer, Microsoft word file is scheduled to run at windows start up. You can remove this file. Type “msconfig” in RUN and press ok.
This command will open Microsoft Configuration Utility.
Click on “Startup” tab, here you will see many files marked with tick. Remove the tick from that word file, which is bothering you.
After this process, restart your computer.
Now you will not see this file any more.
Regards
