Word Doc To Tiff Conversion
When I work, the quality of my jpg image degrades when I use it multiple times. Can I use tiff files for that? I want to convert my Word doc to tiff image file. What should I do?
Yes, tiff files are more lossless than jpg files. However, the size is greater than the other file formats.
The versions of Word 2007 or more gives you the facility to convert your Word doc to an image file using Paste special. • Select the area which you want to convert.
• Copy it or use Ctrl+C.
• Open another Word document. Paste it as paste special.
• Select Picture (Enhanced Metafile). Click OK.
• The selection has now become image after copying.
• Right click the picture. Select Save as Picture.
• Select tiff in the drop down list of Save as type field.
