Word document error opening bilingual document
20 points
Posted on - 09/19/2013
I just got this error message when I tried to open a file using MS Word but the error says “This file cannot be processed because it was saved as a bilingual document in Word. Only monolingual files are supported”. Now I can’t understand how accidently I saved the file as bilingual. Has any solution to resolve this issue? Thanks for help.
Error
This file cannot be processed because it was saved as a bilingual document in Word. Only monolingual files are supported.
