Word how can I lower the macro security
Generally, a message bar is prompted when a document with macros is opened, you can click on “Enable Content” to allow macros. Else, follow the following steps to enable Macros at Backstage view.
1. Navigate to File > Info > Security Warning Tab, Click Enable Content.
2. Under “Enable All Content”, check “Always enable this document’s active content” to make the file a trusted document.
You can lower the security of Macros by navigating to Tools Menu > Macro sub-menu, Select Security.
Select the desired level of security under Security Level Tab. Then Click OK. It is recommended not to set the security level “Low” to enable protection from viruses.
