analyn
10 points
Posted on - 08/11/2011
How do the hyper cache will be useful on pro plug-ins? Does it useful for the Word Press plug-ins? What include to the external web page of the Word Press? Word Press 2.5 what will be there short cut code?
Daniel
Word Press plug-ins and external web page
Mask almost all external links – Make sure they are internal or perhaps disguise. On your own content, comments Web pages, creators page – no more PRCY falling!
Plug-in is designed for experts which market different sort of advertisement on their web site (for example, together with shape system) and also care about the amount of outgoing back links that may be found by search engines like Google. Now you can make almost all external hyperlinks – inside! In your content, remarks Pages, authors page… Plug-in doesn't change anything at all or even write to bottom – merely techniques result.
Right now you don't need to worry about the pr or index, shedding due to junk e-mail crawlers. You write any type of http website link – plus it becomes internal or even hidden! Of trigger, every one of the back links will still be functional.
A plug-in or plugin is a piece of software that contains a set of functions that you can add to an application, web app, or web server like in WordPress. If you have a WordPress website, you can add or install different plug-ins that will help you maintain your website and give additional function or feature. They can extend the functionality or add features to your WordPress website.
Plug-ins for WordPress websites are written in PHP and integrate flawlessly with WordPress. The Hyper Cache is a cache plug-in written particularly to achieve the maximum speed for your WordPress website. You can use it on low resources hosting and also on high end servers. This plug-in is purely PHP and works on every blog.
Hyper Cache doesn’t require complex configurations to work and leaves no stale settings when deactivated. A short list of its features includes:
- Mobile aware – double cache or dual cache for desktop and mobile site versions
- HTTPS ready
- Mobile theme switch option – changes the theme when a mobile device is detected
- Can serve expired pages to bots to increase the perceived blog speed by bots
If you want to try it on your WordPress website, go to Hyper Cache and download. The Hyper Cache plug-in requires WordPress 3.9 or higher.
