Work Arounds On How To Open Unblock YouTube Given
I am looking for methods on how to open unblock YouTube in my country as some videos are blocked here in my country and I want to access them. I need solutions for this.
To open unblock YouTube, you can try the following-
You can try anyone of the following.
If you want to watch videos on YouTube but there are ones that are blocked in your country or in your current location, the best remedy as always is to use a proxy but unfortunately it is not free most of the time. Proxy eliminates the boundaries if certain content is blocked from one country or region.
If you have or use Opera, you can use a plug-in called SurfEasy Proxy. It is an add-on for the Opera browser that will allow you to visit websites that are blocked in your country. It allows you to use its service to hide your actual IP address and use an IP address from one of the 13 different regions located around the world.
If you install this add-on on your Opera browser and you watch a video on YouTube, you will appear on YouTube as if you are located from a different country therefore allowing you to watch any videos without getting blocked. When you install the add-on, you need to sign up for an account.
