Working And Definition Of Remote Desktop Services
What is the definition of remote desktop? What is the purpose of it? What is remote desktop protocol? What are the advantages of remote desktop?
Remote desktop is a program or a feature of the operating system that allows the authentic user to communicate and interact with the desktop from another location as if it were local. The main purpose is to interact with the data available in the desktop remotely. The remote desktop protocol is used to make sure that is data transfer and connections between two computers are secure. The advantages are that access to the system from anywhere and anytime, low maintenance cost, advanced security feature, supports all hardware, and much more.
Remote Assistance or Microsoft Remote Assistance is a feature not only in Microsoft Windows 7 but other Microsoft Windows operating systems as well from Microsoft Windows XP and higher. It allows a user to temporarily view and control a remote computer running on Microsoft Windows, frequently over the internet, to fix problems without literally touching the unit.
It is based on RDP or Remote Desktop Protocol. Remote Assistance in Windows Vista is based on RDP 6 and Windows Desktop Sharing API. This version of the Remote Assistance is a standalone program that doesn’t use the Windows Messenger or the Windows Help and Support Center. This allows two systems administrators to connect simultaneously to a single computer.
Remote Assistance in Windows 7 is based on RDP 7 and uses Peer Name Resolution Protocol when connecting using the Easy Connect option. With Easy Connect, you don’t need an invitation file to initiate a session. You only need a password and two computers to start a peer-to-peer connection over the internet or local area network without the need of a relay server.
