How can I convert to/from the c programming language and other languages such as Java, VB, C#, using an instant c converter? Tangible software provides conversion between C++ and some other common programming languages, but what about C? For example some hardware such as chip programming requires programming in C (not C++).
Would like an instant c converter to convert between the various languages?
Hi Bobbye W Terry,
It is not advisable to convert c program into different programming languages, although there are available on the internet but those converters aren't accurate enough to convert the whole program and function the way it was before. The thing is, the logic and syntaxes are difficult to analyze so that on converting the program in different applications or other programming languages, they are using plugins that will help in order to view let's say C into the Java applet.
