Would like to have a search activator ipad compatible, is NowNow iPad compatible, it is mentioned on ifans under iOS Ecosystem but does not say whether it will work under iPad, iPod, iPhone, or which iDevices?
Would like search activator iPad compatible, will Now do it?
Hi Young Hernandez,
Activating a device requires you to pay for their website support. There are the store.apple.com that is available for transactions for every activation that you will be needed, the range costs from free up to $99.99 depending on the software's quality and credibility. The payment can be of credit card or bank account.
Now is a new application that works the same as siri. It helps one to communicate with the gadget that they are using with manually touching it. This application will allow one to set Google voice search as an activator action. It is very compatible with any apple product. Enjoy the application.
