I have an LTE LG Optimus F7 that has Dual-core 1.5 GHz CPU, Android 4.1.2 Jelly Bean and Handcent Punisher theme. I was wondering if updating Handcent would delete my theme? I'm trying to install version 0.4. Any feedback on this? Thanks.
Would update delete Handcent punisher theme?
Hello Alfredo T Collins,
I read your question and I think know the answer – NO, it will not delete your Punisher theme. You can install without worries Handcent 0.4. The market updates only added and removed files as necessary, not that they loaded the entire program again. You could use some backup software , and restore if it's an issue – and then don't update
Regards!
Nathan H UnderwoodÂ
