Hi experts,
I am trying to find Visio 2010 patches. Would it possibly correct my problem, because it consistently crash.  Need to uninstall and reinstall it, is there another way to solve this. Please give me solution.
Thank you
Would Visio 2010 patches help?
If you are facing this problem again and again then its not a problem with Visio.
There might be 3 reasons for that.
Firstly, it might be due to malware issues. They might be corrupting your files and causing you such problem.
Secondly, it might be due to cluttered system that is the presence of a large number of files in recycle bin and temporary folder.
The last reason might be the presence of many Add-ins on your system.
So if you check for above 3 issues then your problem might get solved.
