Write protected Pen drive formatting
I can not format or even delete any folder from my pen drive.
While formatting a message appears " The drive is write protected".
What will do I now?
What will do I now?
Your pen drive is corrupted with virus and the data in it is also affected by it. For this reason you cannot delete any folder from your pen drive, even you cannot format it. That’s why it is showing the message – write protected. It’s normal. If you want to format your pen drive you can do the following:
1. Scan your pen drive with an updated antivirus successfully. May be the antivirus presently running with your PC not strong enough to scan your pen drive in this position. You need some upgrade version.
2. You have to keep in mind about backup any important data before formatting.
3. Now you can format your pen drive.
I hope you understand it.
Thanks
This is a common problem with a simple solution.Please follow the steps below:
