Wrong log in email credentials
Clients have encountered the following error message when they enter with false credentials.
“11:02:26 ERROR ActiveDirectoryUserDatabase – Could not get the service account login context. Some features such as account maintenance will not be available. javax.security.auth.login.LoginException: Client not found in Kerberos database (6) not found in Kerberos database”
Please advise and thank you.
Answered By 0 points N/A #136760
A prompt, “Client not found in Kerberos database” is one typical error that commonly occurs on Active Directories.
As you can see in the statement of error, it reminded you that; “Could not get the service account login context. Some features such as account maintenance will not be available. javax.security.auth.login.LoginException: Client not found in Kerberos database”.
This error, in numerous occasions, comes along when wrong identifications of client are entered.  This problem can be sorted out by simply making sure that every particular logged into the fields are accurate and precise.
I hope this helps solves your question.
