Wscuiex.cpl is not a valid win32 application error
I was running the Mozilla Firefox when I received this error message “Error Loading C:WINDOWSsystem32wscuiex.cpl, 1% is not a valid win32 application.”
Error message “Error Loading C:WINDOWSsystem32wscuiex.cpl, 1% is not a valid win32 application. ” shows that your Mozilla Firefox become corrupt due to virus and your aunty opinion in this matter is right. You have to adopt two options for resolving this issue / problem.
1. First uninstall Mozilla Firefox and download a fresh copy of Mozilla Firefox from website.
2. Install any antivirus software which are easily available on web i.e AVG, Avira, Avast Antivirus. After installing, upgrade its virus definition and scan your complete system through antivirus and remove / fix all virus.
take care
kelin
You normally receive that error when running an unsupported program on your computer. But if it is with Mozilla Firefox, the problem is probably with the files. Try to uninstall and reinstall the web browser. Download the free version of Revo Uninstaller and install it. Once installed, start Revo Uninstaller then select your Mozilla Firefox among the applications and click “Uninstall”.
Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer. When it is finished, close Revo Uninstaller then install Mozilla Firefox back. This should fix the problem. Try also installing the latest. Go to the Mozilla Firefox home page to get the latest.
