Wuala network drive error, unable to synchronize
My Windows XP SP3 computer has a Wuala installed on it. On it are folders that have a huge capacity that is synchronized with the LaCie Network.
I mainly use this disk for my files and to save the files online I would use Wuala to do it automatically. Wuala is used on a daily basis. However the network drive is most of the time turned off to avoid over usage of the device. The drive is also booted in order to synchronize it fully.
All was working well until an automatic update has made an error message pop up on the screen saying that the network drive is turned off and it is not possible to synchronize. The only option I have is to click on OK but when I do that, the error is still there and I can only get rid of it by closing Wuala and it would disappear.
How can I have my usual setup without getting this error message? Is it possible? Thank you for your assistance on this matter.
