I was playing a game last night but now I am getting an error in ubi with error code 0_35. I visited www support ubi com error code 0_35 and found solution that says remove the firewall and the game will start working. I did that but the issue remains the same. Can anyone help me solve this error?
Www Support Ubi Com Error Code 0_35
Hey guys, try to solve this problem by modifying an anti-virus code or personal firewall that will be added to your system. This includes your Windows firewall when you change the firmware of your home router. If changing these programs does not solve the problem, you must shut down the associated program or bypass the router and connect to your device immediately.
- You may want to configure your router or firewall to allow the following network ports for the easiest possible connection:
Uplay Launcher:
TCP: 80, 443, 13000, 13005, 13200
The instructions for configuring network ports are specific to the code and hardware used and can be obtained from the manufacturer’s website.
- Disable your background applications:
To do this, launch the Start menu on your desktop (or simultaneously press the Windows key and the letter R if you are using Windows Vista / Windows 7).
Enter MSCONFIG and press Enter
Go to the “Start” tab
Click the Disable All option. Tap Apply, then close and select the Restart option
- Delete your temporary files:
To do this, launch the Start menu on your desktop. Tap to try pressing Enter. Go to Edit and select All.
Go to File and Delete.
- Try to delete your HOSTS file by typing the following path in Windows Explorer: C: \ Windows \ System32 \ drivers \ etc. Delete the Hosts file and retry the game.
