X-Openproj cannot access a folder and shows error
Whenever I attempt to access this folder in winPenPackLibJava" path I get the following error message. I really cannot understand this error and the main cause of this problem that’s why I expect a reasonable solution to fix this issue. Thanks for any kind of help.
X-Openproj
ERROR! “C:winPenpackLibJavabinjavaw.exe” not fount!
Answered By 590495 points N/A #167663
I think your application may have a missing file or if it is not missing it could be corrupted that’s why it can’t be accessed. The problem is not with the folder you are accessing but with a particular file called javaw.exe which supposedly located in “C:winPenPackLibJavabin” folder.
You may try navigating to this location in your system drive using Windows Explorer to really see if the file is really missing or not. There is also the possibility that the file got renamed accidentally or the file is moved to a different folder. Sometimes when a program has been updated, several of its files and folders are being transferred to a new location.
If you still have its installer, you can uninstall it and then install it back to restore the file. Or it would be better to just upgrade it to the latest version. Visit winPenPack 4.3 Essential Full Personal to download the latest release. Once downloaded, uninstall the one on your computer and then run the newly downloaded installer.
wPP is the shortened name of winPenPack. It is an open source application suite designed for Microsoft Windows. It is actually a collection of open source programs that was modified or customized so it can be opened directly from a USB flash drive or other removable storage devices without the need of further installing it simply making it portable.
