X plore uiq 3 compatibility
Hi , everyone! I've heard about this cool file manager for certain Symbian OS phones. Does any of you here has an idea about x-plore? Are there any x plore uiq 3? My phone model is Motorola Z8 and its under the uiq 3.x section. Is my phone model compatible to x-plore? If yes, how can I install it on my phone?
Best Answer by Mcdonald Larimore
Answered By 0 points N/A #179871
Greetings,
Xplore is a great manager; I have used it for the last number of months on my android phone and it works great.  It changes how you navigate among different files to give a new cool look. For Symbian OS, specifically for your phone type, it can be downloaded from the Symbian play store.
Answered By 0 points N/A #179872
Hello Julio,
You have made the right choice of trying X-plore for your Motorola Z8 phone. It is a perfect file manager for your phone and works fine with Z8. Along with file managing capabilities, it offers other features such as –
  • Tree view to list drives, folders and file on the phone
  • Inbuilt image and text viewer.
  • You can view and edit file attributes.
  • Allows you to copy, create, edit and delete folders and files.
  • Gives you information of the hardware devices on your phone.
And about the installation, you do not need to install it on your phone. Just download the file, store it wherever you want on your phone and just launch it to start using it.
Here is a snap showing the tree view offered by X-plore –
