X ray scanner for Smartphone
Hay guys I need a good X ray scanner for smartphone, I have a galaxy ace. I need to make some fun with my childs through it. So it should not look like toys. I mean I need the best one. Please help me.
Hi Christopher Jay,
If you are looking for a good x ray scanner app for galaxy ace. you can directly download from Google play/Market.
another source for a good quality x ray scanner app for galaxy ace is mention below:
https://mob-core.com/en/samsung-s5830-galaxy-ace/programmy-dlja-android/554-xray-scanner.html
download and install .
I hope it will be fruitful. Thanks!
Hi there user:
Like for real x-ray scanner is already available on the market. Tried and tested it by myself. It’s available for all android phones so it’ll surely compatible for your Galaxy Ace. Purchase it via Google Play Store, and have a test for yourself. I can say it’s the best x-ray scanner presently.
Thank you for posting.
Best regards,Â
If you are looking for a good x ray scanner app for Nokia N97. you can directly download from Nokia store.
http://www.mobiles24.co/downloads/tag/X-ray+Scanner/nokia-n97-mini-java-apps
download, install and Enjoy .
I hope it will be Helpful for you.
Thanks!
Really I did not use that, but i recommend you to go toÂ
http://www.mobiles24.co/downloads/s/618699-m1130-x-ray_scanner_pro
Download and install from it or from Nokia store.
The X ray scanner software is an innovative application which you can download on your Smartphone. You can browse applications on your Smartphone to get the software or can download on your PC and the transfer to your Smartphone through USB cable. You can find details regarding the software from the site:
However, X ray scanner software is not the application like other Smartphone applications. It is used for another purpose. You will get those elaborately from the site mentioned above. Some of them may cost money and some of them are free. Your highest satisfaction will be upon the performance of the software you used. Â
I hope you understand it.
