X ray scanner for Smartphone that will work on androids
Hi guys I am looking for an x ray scanner for smartphone that will work on androids? Which one will be best?
Hi Alberto Dexter,
You are looking for x ray scanner app for smartphone. You can find this app through the Android Market/ Google play. If you want to download from external source you can download from below mentioned sites:
https://appworld.blackberry.com/webstore/content/59987597/?countrycode=US&lang=en
https://play.google.com/store/apps/details?id=ru.royalgamesapps.wholebodyxrayscannersimulatorjoke
I hope it will be helpful. Thanks!
Hi Alberto,
Here are a few x ray scanners that are available on the Google Play Store.
All of these apps are on Google Play store and so they are fully trusted. You need not worry about spyware of virus while downloading them. They are completely safe to download.
Hope this helps!
Drianna allen
