X3 time of the truth map not loading properly.
X3 time of the truth map is not loading fully. I can start playing but I cannot see the full map at a time. I have Windows 7, i5 on my laptop and I have installed V1.2 of the game.
I see that the X 3 time of the truth map is not getting loaded when you are playing the game. It happens because the video memory requirement is not met. The game is not allotted the amount of video memory that it requires. You can resolve this problem by either increasing your video memory or by changing the game mode to the compatibility mode.
To change the game mode to the compatibility mode, follow the steps below:
1. Run the game from the desktop on your computer. If there is no desktop icon then go to the folder where you saved the game and right click on the exe file and click create shortcut. Then select the location as desktop and click ok.
2. Now, click on the options in the main menu of the game.
3. In the options menu go to video options. Select the resolution that best suits your computer. Then select the compatibility mode option on click on save changes.
Now, your problem should be resolved.
Notifications
