X360ce Failed To Load Xinput1_3 Dll
Hello, after filling my x360ce, an error comes that says x360ce failed to load xinput 1_3 dll, System.ComponentModel.Win32Exception (0x80004005): Can not find the requested module after trying to do it for hours, can someone help me to solve these things?
Answered By 30 points N/A #320980
You should make your system requirements done and completely fulfilled then only you will get successful in doing this. The requirements for the same are:
Windows 7 or later.
.NET 3.5 (also includes two.0 and 3.0) (included in Windows 7)
.NET 4.0 (link to Four.6, also adds Four.0) (included in Windows 8 and 10)
DirectX End-User Runtime (June 2010) (required, regardless of the operating system)
Visual C ++ Redistributable for Visual Studio 2013
ALL must be started and restarted.
Run x360ce.exe as an administrator
Answered By 590495 points N/A #346141
That problem is with the controller you are configuring. If you are connecting a gamepad controller on your computer, make sure the driver is installed properly. If you already installed the gamepad software, check the system requirements again and verify your computer meets those requirements. Download .NET Framework if required:
