shellyylove
60 points
Posted on - 08/23/2011
I am web developer and I am doing work in XAMPP tool for designing any site but from previous 2 days it is not working I am very confused about this error.
I need experts help.
I paste my web data in this folder C:xampphtdocs but when I try to access it I receive error.
All Error detail is here:
/Applications/XAMPP/xamppfiles/bin/
apachectl: line 70: ulimit: open files:
cannot modify limit: invalid argument
        OK
Please tell me here is coding problem software corrupt or any file deleted by me.
Why this error appears.
XAMPP cannot modify limit invalid argument
If you don't have any problem working with your web data before, the problem would be in your web designing tool.
I think a portion of the XAMPP software permanently crashed, and when you are already doing the project, it can not handle the loaded data that is why it is giving an error.
Try uninstalling XAMPP then run a disk check afterwards.
Right-click on drive C and then choose Properties.
Click on Tools tab.
Under Error checking, hit on the Check Now button.
Choose Automatically fix file system errors under Check disk options.
Click the Start button to start checking your hard drive.
Wait for it to finish then install again XAMPP afterwards.
It has a fresh configuration now I’m sure it will run normally again.
