sinthiamem
Posted on - 08/24/2011
Some time my Ubuntu operating system create problems. Yesterday I wanted to install my Xampp software. I know that Linux operating system support only for Linux supported software. Mainly I followed the installed system but I can’t do it. This is very difficult for me.
What is processed and how can I install a Xampp software on my Ubuntu operating system?
jon durf
Xampp install process in ubuntu os.
To install Xampp on Ubuntu use this step:
1. Downloaded .tar.gz archive software and go applications then Accessories then Terminal.
2. Login as the super admin on your computer.
3. Start to install Xampp by giving this commandOpt/lamp/lamp start.
It will begin to start Xampp installation. At the time of starting Xampp just open a browser and go to localhost and follow instruction carefully. A window of this type will appear. Just read carefully what it says and do as it says.
After that the install progress will be finished. Now restart your computer and then run Xampp.
