XAMPP server is not responding
Guys,
I installed XAMPP 1.7.7.
But when I am trying to go http://localhost/phpmyadmin, it is telling me “access denied, this server is not responding”.
How can I fix it?
Thanks
Guys,
How can I fix it?
Thanks
Your PHP myAdmin page does not appear for setup problem. When you installed this software you did not followed proper method to install it. That's why this type of problem occurs in your computer. You needs to adjust your setting once again. You should delete all files and folder of XAMPP software for fixes your bug.
At first delete all of your previous setup files from your C:/ drive. Double click on My Computer and then Open “Program” Now select “XAMPP” and then delete that folder for you computer.
Let install your XAMPP software once again and then try to open your PHPmyAdmin
Thanks
