I would like to get your feedbacks regarding the Xandros Linux Desktop OS 3.0 Deluxe Edition. Has anyone here tried it already? Some say that its firewall/ security features are totally dependable. Can someone give me a brief, through each upgraded features from file management down to security system? Thank you.
Xandros Linux Desktop OS 3.0 Deluxe Edition feedbacks
Hello there, Xandros Linux Desktop OS 3.0 Deluxe Edition is very easy to install. Just put the install CD in, and the computer will boot from the CD.Within a minute or two, the main installation screen will show up. You have the option of allowing Xandros to take over the entire hard disk take over a partition and make a new partition. Next, Xandros will ask you to choose what kind of installation.Then you will give the computer a name, and you will also enter in a password for the administrator.
Next, just kick back as Xandros installs on the hard drive. Once the install is complete, the CD will eject and you press enter to restart the computer. Xandros is very easy to install.This is an OS with an easy install, the cost savings of a Linux environment, easy installation of additional software, the functionality of a Windows-like GUI, and the adware-free, spyware-free security you would expect from a Linux system.
