janajacobb
Posted on - 05/29/2012
I’ve recently tried the new version of Xara photo and graphic designer, MX 8.1. The installation package is horrible. I am facing problems with the handling of regular files now. Do I have to install anything else or remove anything? Please suggest.
Xara Photo and Graphic Designer MX 8.1 issues
Maybe you did the installation incorrectly that’s why you are now having problems with your own system. It’s also possible that the installation encountered a system incompatibility problem but this will only happen if you are using an older version of Windows.
I’ve read the system specifications of the program and I think it will not work on earlier versions of Windows like Windows 98, Windows 98 Second Edition, Windows Millennium, or Windows 2000.
If the application is already installed on your system, try uninstalling it first so you can also check your machine for other problems. When the program is completely removed, check your computer for any possible errors. Use a disk utility application to check the system. After this install Xara Photo and Graphic Designer MX 8.1.1 again and test it if it’ll work after the installation.
To review the system requirements of the program and also for you to better understand it, Xara Photo and Graphic Designer MX 8.1.1 supports Windows XP, Windows Vista 32-bit and 64-bit, and Windows 7 32-bit and 64-bit.
This version requires around 300 MB of your hard drive’s available space.
This version was just released last June 4, 2012 and is really very fresh. To download this version visit DownloadCrew.
